Hello i have a new MSI 4060 Ventus OC GPU which works fine, temps included.
Sometimes when gaming i get a weird sound, it doesnt always happen but only some games seems to trigger it. Also running graphical benchmark like superposition doesnt trigger the sound even if the fans spin pretty fast. Im 100% sure its not coil whine since i got this sound while putting the fans at 100% and back to 0 with msi afterburned while on idle.
View: https://imgur.com/a/f180mXl
View: https://imgur.com/FidXIc1
This is how it sounds like.
Someone knows whats casuing this? Does it sounds like the fans bearing are bad or maybe its the gpu bracket vibrating? Its pretty loud when it happens.
I hope someone can recognize the issue from the sound.
TY
TY
