help with graphics card capabilities
gooniin
38
looking to see if my gpu and cpu combined are enough to run skyrim, crysis1+2, BF4, and farcry3 at max-ultra settings with a fps of 50+
Here are my gpu and cpu
( SAPPHIRE 100355OCL Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card OC Version)
(quad-core AMD A6-3620 2.2 GHz processor)
FX 6300 + R9 270 or Fx 6300 + GTX 660 will run perfectly on high settings
OCed 7850 also will do the job with a better CPU, but when you pair it with A6 3620. things will get shaky.
prudhvirazz
312
7850 + A6-3620 will not meet your requirements. Not even close. You need a much better CPU for sure and also a better graphics card.
i5-4670k + GTX 760 or equivalent AMD build will do the work at 1080p.
gooniin
38
can i atleast run them on high with good fps? people are saying with the sapphire 7850 OC there getting hip fps on max resolution
prudhvirazz
312
