Help with graphics!?
iiHeroz
8
Hello, right now I have a gt 640, and I need to upgrade that immediately. I was looking at the gtx 760 or 770. Which one would be best to get? Also, what do I need to know before purchasing one, stuff like a new power supply for the wattage? For the 770 I know I need a minimum of 600W and for the 760 I know its 500. Could you recommend me a good power supply as well? By the way, my computer is a Dell XPS 8700 which I bought awhile ago.
Specs:
8GB Ram
Gefore GT 640
Intel Core i7-3770 @ 3.40 GHz
You're on the right track with the PSU concern. Use this tiered list to find a PSU of good quality. Try to stay in the 1st 2 tiers if possible, the 3rd tier at most.
https://community.newegg.com/eggxpert/computer_hardware/f/135081/t/45344.aspx?Redirected=true
If you have a budget you can spend on a PSU, let me know. I will try to find you a good PSU at that price range.
The current capacity of the +12V rail(s) and the total wattage that rail can handle are the most important thing when sizing for a gfx card.
Would these two be any good?
http://www.amazon.com/gp/product/B00ALK3KEM/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
http://www.amazon.com/gp/product/B00DHW4HXY/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Ok, im not exactly sure what power supplies will fit in my case, which is the DELL XPS 8700 stock case. But, that looks like a pretty good PSU. Also how many amps max on the 12v rail is the power supply you gave me and mine? Cant seem to see it
Thank you so much for the help, going to buy the corsair because I may want to upgrade my graphics card in the futute. Thanks again!
