Question Help with Group Policy drive mapping for certain users within an OU ?
Brownie93
16
I'm needing some help with Group policy.
I have an OU named "Terminal server" in AD that holds all the users that work on a server. I have created a new network share for just Customer Service and I want to map this drive to them automatically, however they are within the "Terminal Server" OU and I don't want everyone in there to get that drive map. I've created a Global Security group with the select users part of it. I then created a Sub OU Called "CS" within the "Terminal server" OU, dropped this group into here and created a Group policy to map the drive and then linked this policy to the "CS" OU. I forced a GP update on some of the users within the group and the drives mapped but for some users and others it didn't which I find very strange, I did this locally on their machine. On the server it hasn't mapped at all.
Sorry if it's wordy and if you need more information I can provide it.
Attached the settings of the GP drive map
This:
"I forced a GP update on some of the users within the group and the drives mapped but for some users and others it didn't "
How did you map the network share?
How did you do the "force"?
Compare the configuration and policy settings of a "successful" end user to an "unsuccessful" end user in the CS OU.
Hi Ralston
The users are within a group so I can't compare the configuration of different users as it should be applying to them all equally if you get me?
To do the force I went to the users machine that was already logged in and went to cmd and entered the command: gpupdate /force
