Well I have 2 IBM hard drives both 30.7 GB and 7200 rpm. The problem is that I'm trying to set those two up using RAID 0+1 and I've been looking for a IDE RAID controller card that would do it. I found the one by Promise, but it says that in order to have 0+1, you need 4 HDDs and only 2 HDDs can have RAID 0 or RAID 1. Is this correct? Then I found a card from Epox that says it can have RAID 0+1, but I only see two channels (sockets) for IDE while the Promise card needed 4 channels. I'm new to RAID and I'm not really sure how to set it up. So would the two drives go on the same channel or on seperate channels? All I want to know is the best configuration for RAID 0+1 using 2 IBM 30.7 GB, 7200rpm HDDs and how to set it up I guess. Anyways thanks to anyone who helps me.
