Question Help with Intel Core i9-9900KS AiO cooler
Dec 8, 2019
6
Can you please help me, I have Intel Core i9-9900KS, but now I need AiO to cool this CPU, and I don’t know which one to chose. I have Cooler Master 25th Anniversary Case, so can you help me with advice which cooler to chose that is going to fit into this case and to give a really good cooling to my CPU?
For a 9900ks you will be looking to a buy a high end 360mm aio to cool it.
Luckily your case supports 360mm aios, so thats what id reccomend.
Deepcool Castle 360mm aio
https://pcpartpicker.com/product/K4848d/deepcool-castle-360ex-644-cfm-liquid-cpu-cooler-castle-360ex
Thank you for the replay, here are the cases specs
It says here that it supports max 320mm radiator for AiO cooling, so will it support the one you suggested?
Yep it will fit without any issues.
Sorry to bother you, but I have just checked and I can not buy the AiO that you have recommended me in my coutry(I am from Serbia). The best I can buy is
Will this one do the same as the one you have recommended me, and will this one also fit into my case without any issues or problems?
