Question Help with low FPS with a 3060 and current hardware.
Oct 12, 2023
So I have a 3060 and I can barely get 50 fps on MW2 with medium settings any ideas on if something is capped or throttling my frames?
Specs.
Motherboard: MSI X570S MPG EDGE MAX WiFi
CPU: AMD - Ryzen 7 5800X3D 3.4 GHz
Ram: CORSAIR - VENGEANCE RGB PRO SL 32GB (2PK × 16GB) 3600MHz DDR4
Storage: 2tb Samsung 990 pro m.2
GPU: GIGABYTE - NVIDIA GeForce RTX 3060 12GB
Cooler: CORSAIR - iCUE H150i ELITE CAPELLIX XT
Reactions: Order 66
Specs.
Your specs look plenty capable. Model and age of the PSU? You can try a few things. 1. update drivers if updates are available. 2. Uninstall drivers using DDU. 3. Check temperatures of both CPU and GPU. If the temps are high (90+) that could explain why your performance is low.
I just got my EVGA - SuperNOVA 1300W GT Power Supply back in March so it’s not old. Temps are always around 60 at the most 70 I could be wrong I would need to check later today when I get a chance. All my drivers are up to date but I’ll try using DDU
Reactions: Order 66
