Question Help with motherboard and GPU
May 31, 2019
24
Hi,
I am looking to Upgrade my Graphics Card, I currently have a Zotac GTX 1060 Mini and I'm going to be upgrading to a EVGA GeForce RTX 2070
However, I'm unsure as to if this card will fit with my motherboard or not.
The motherboard that I currently have is the Gigabyte H110M-S2H Micro ATX Motherboard
My PSU is the Cooler Master 600W ATX Power Supply MasterWatt Lite which has 2 x PCI-E 6+2-pin
and the RTX 2070 takes one 6-pin and one 8-pin power cable, so am I correct in being able to connect the 6+2 pin to fit the 8 pin slot, and then just connecting the 6 pin to the 6 slot of the graphics card.
I have checked the space in my case and I have more than enough room so that wouldn't be an issue, just confused on if I need to have a Mini Graphics card since my motherboard is a Micro ATX, or if this normal size RTX 2070 will fit.
Any help regarding this would be greatly appreciated!
