Help with my $1000 budget pc build
Dropment
855
Im going to be build a new pc towards the end of this year that it $1000 give or take
I want to be able to watch videos on twitch and yt while gaming and also gaming while streaming at 1080p60fps. I first went to ryzen as a platform right away mainly because i never had an amd system and they are the king at multitasking.
https://pcpartpicker.com/list/2kY2jy - heres my parts list
I can go with the ryzen 5 2600x and upgrade to ryzen 2 or get a 2700x . They gpu i would be using is a gtx 1070 or if i can get a good 1080 deal
Thanks in advance, dropment
Your build isnt bad. Just made a few tweaks to it, without changing everything. https://pcpartpicker.com/user/FrostyFresh/saved/BbzvnQ
I like the 2600x. I would say use the stock cpu cooler at first. If it's not enough for you change it later. I'm sure people will say get a better PSU. I dont know if there was a specific reason you wanted that motherboard. But I think you can get the same options for less money.
Prices should change by then, but you have the specs about where I would think a good 1k$ pc should be. Best bet would be to post again when you are ready to buy. That way people can get more specific on the different deals going on.
