help with my build?
Basically the same build but here is a smarter use of money.
PCPartPicker part list: http://pcpartpicker.com/p/yDzGnQ
Price breakdown by merchant: http://pcpartpicker.com/p/yDzGnQ/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($199.98 @ SuperBiiz)
Motherboard: ASRock H97M Micro ATX LGA1150 Motherboard ($75.66 @ Newegg)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory ($72.99 @ Amazon)
Storage: Crucial M500 120GB 2.5" Solid State Drive ($70.32 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($52.92 @ Amazon)
Video Card: EVGA GeForce GTX 770 2GB Superclocked ACX Video Card ($309.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: XFX 650W...
I see quite a few things with this build.
1. The CPU cannot be overclocked (since you asked)
2. The motherboard does not support SLI but does support Crossfire. However you are set on an NVidia GPU, so you should change your motherboard.
3. The 1 TB hard drive is way to expensive. You can easily get a 3 TB for $100, 1 TB for $55-$60, and a 2 TB for around $85
4. Your power supply is enough for this build in its current state, but if you want to SLI two of your GPUs later on, you may need to change the PSU.
5. What operating system do you plan on using?
im not planning on getting two gpu's like sli or crossfire and it really don't know what operating system to get I don't care if is get windows 8 or 7 and I really don't care about overclocking I just wanted to know "IF" I can and know I know...
Okay, then you could save some money on the motherboard by going for a micro atx board that only supports a single gpu.
Update:
I asked about the operating system because some programs and applications work better with Windows 7 (well most do anyway). And if you go with Windows 7, then you would need to go with 64bit version of Home Basic to ensure you can use a max of 8 GB of RAM at one or 64 bit Home Premium or better for a max of 16 GB of RAM. If you go with Windows 8, you don't have to worry about the RAM limits like that but I would say to still go with 64 bit.
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($59.99 @ NCIX US)
Total: $891.84
Generated by PCPartPicker 2014-06-17 23:31 EDT-0400
