You got the thing about lots of cores and ram but your storage was way off the mark, you needs lots of it and fast, fast, fast. This is because during processing you will be doing lots of data read/writes. I know that you said to stick with 5960X but I substituted the 5930K and used the money on the storage. As well, I didn't think you needed a 750W platinum, used a 650W gold instead. If you want, keep the CPU and the PSU but improve your storage. Run the 1TB SSD's in a RAID configuration.
For mobo one of my favourites is the ASRock X99 Extreme4
PCPartPicker part list:
http://pcpartpicker.com/p/cCyKYJ
Price breakdown by merchant: http://pcpartpicker.com/p/cCyKYJ/by_merchant/
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($554.99 @ SuperBiiz)
CPU Cooler: Deepcool ASSASSIN II 70.1 CFM Fluid Dynamic Bearing CPU Cooler ($69.99 @ Newegg)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard ($184.98 @ Newegg)
Memory: Crucial Ballistix Sport 32GB (4 x 8GB) DDR4-2400 Memory ($173.99 @ SuperBiiz)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive ($230.97 @ OutletPC)
Storage: Mushkin Reactor 1TB 2.5" Solid State Drive ($258.99 @ Amazon)
Video Card: NVIDIA GeForce GTX 980 4GB Video Card ($549.99 @ Best Buy)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($74.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($17.78 @ OutletPC)
Total: $2445.65
Generated by PCPartPicker 2016-01-27 17:13 EST-0500
