Question Help with New build
Thatoli
41
Hello Tomshardware esteem professionals
I am after help with a new pc gaming build,
-£3500 to 5500 budget
-Based in uk
-X670e or x870e ?
-I’d like 9800x3d and a 5090 when launched
-would like custom CPU cooling
Advice on all the other components would be greatly appreciate.
I only need the pc and don’t need any other items.
I can use my 3080 gpu until the 5090 comes out.
I have a oled 240hz monitor and want to play triple A titles maxed out
Thanks in advance!!
Need to see the reviews on the 5090 before deciding on a psu. Replace the 140mm exhaust fan that's included with this case with the 140mm ARGB fan down below for the full effect.
PCPartPicker Part List
CPU Cooler: *ARCTIC Liquid Freezer III 360 A-RGB 48.82 CFM Liquid CPU Cooler (£76.98 @ Amazon UK)
Motherboard: *Gigabyte X870E AORUS ELITE WIFI7 ATX AM5 Motherboard (£269.99 @ Ebuyer)
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£113.42 @ Amazon UK)
Storage: *Patriot Viper VP4300 Lite 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£99.99 @ Amazon UK)
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case (£109.00 @ Computer Orbit)
Case Fan: *Lian Li UNI FAN SL V2 77.6 CFM 140 mm Fan (£27.00 @ Computer Orbit)
Total: £696.38
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-11-06 08:57 GMT+0000
View: https://www.youtube.com/watch?v=9TfR60pM5oU
View: https://www.youtube.com/watch?v=ykbhuv6yLBc
Reactions: Thatoli
Total: £696.38
Thanks for your suggestions.. do you think I’d benefit from pcie gen 5 storage for faster load times ?
Also I would like to go for custom cpu cooling would this be possible https://www.scan.co.uk/products/the...fBZxP-dsOOtv4EVVnRdjjA3ZkKTIPSehoCuocQAvD_BwE
Is a stopwatch part of your daily attire? If yes, then maybe you'd benefit.
Do you have a strong desire to be on the cutting edge of technology for its own sake, regardless of practicality? If yes, then 5.0 will scratch that itch.
Could you live with yourself if you didn't buy 5.0? Why volunteer for buyer's remorse?
Are you quite insensitive to price? If yes, then "why not"?
Do you have some unmentioned reason to consider 5.0, other than gaming load times?
Reactions: Why_Me
Not really I figured I’ve got the funds so I could future proof as far as possible I suppose, however if the benefits are minimal then I don’t want to waste money for the sake of it.
By the way thankyou for stopping by and adding advice
