Hello,
I am building this computer because I do a lot of 3D rendering for work and it's too demanding for my older computer. I'll also be doing a decent amount of video production and gaming as well, so I wanted a powerful build that could handle that kind of workload.
SPECS:
PCPartPicker part list: http://pcpartpicker.com/list/fwC4nn
Price breakdown by merchant: http://pcpartpicker.com/list/fwC4nn/by_merchant/
CPU: Intel Core i7-6950X 3.0GHz 10-Core Processor ($1649.99 @ B&H)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($129.89 @ OutletPC)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard ($174.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($79.88 @ OutletPC)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive ($317.99 @ B&H)
Storage: Samsung 850 PRO 2TB 2.5" Solid State Drive ($834.00 @ B&H)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card ($975.49)
Case: Cooler Master Cosmos II (Black) ATX Full Tower Case ($309.97 @ Newegg)
Power Supply: EVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply ($177.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.88 @ OutletPC)
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($129.88 @ OutletPC)
Wireless Network Adapter: Asus PCE-AC68 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($92.96 @ B&H)
Monitor: Asus VS278Q-P 27.0" Monitor ($193.98 @ Newegg)
Keyboard: Das Keyboard 4 Professional Wired Standard Keyboard ($165.99 @ B&H)
Mouse: Razer Naga Hex Wired Laser Mouse ($79.99 @ Newegg)
Total: $5717.81
Generated by PCPartPicker 2016-07-28 08:36 EDT-0400
I only have a few questions about this build:
1.) Should I be using more than a 1000W PSU? PCPartPicker is saying that these parts technically use less than 500W, but I don't believe that for a second, especially since I'm probably going to overclock the CPU a bit.
2.) Is the Corsair H100i enough cooling for the system, or would you recommend something more? This computer is going to be in my air-conditioned apartment and it never goes above 80 degrees farenheit (~26.6 degrees Celsius,) but I don't know if that would affect the PC at all.
3.) Are there any parts on this build you would recommend I swap for others? I'm going for maximum performance possible. I'd rather spend more to have a better-quality build.
Thank you for your help!
SPECS:
Total: $5717.81
