Help with Nvidia SLI!
thewhighet
41
Recently I ordered an extra 650ti boost oc twin frozr card. Now I have two. Everything is running and the bridge cable is connected but how do I know its working? In the nvidia control panel, where do I tell it to recolonize the new card? Thanks.
Yes, always uninstall the driver and re-install after putting in the new card(s). At least that is the only way I can get mine working.
control panel "configure sli"
make sure it is set to "maximise 3d performance"
then go to click on "3d setting which is at top of control panel and tick the
"show sli indicator"
when you play game you should see the sli green line indicator to show you that sli is working.
The SLI option shows up nowhere for me. I ordered the card used. Do I need to uninstall all my drivers and reinstall? Should I use the CD that came with my graphics cards?
