So, i have an old hd 6790, which at around 99% usage goes up to 100° or more, which you know, is kinda hot, i have cleaned it, changed the thermal paste, airflow is alright, but i think it could be something but im not sure, should the cooler ( like the copper part of it) touch the gpu (the chip)?, because i dont think it is exactly touching it, i have investigated and this card at 100% usage should be at 70° maximum, and if its not this i dont know what else could be, i will try to upload a photo but i dont know if you can see it,
you can see its not touching it, so i think it might be a reason for such an overheat, btw, thanks
Forgot a detail, it goes to 100° with its fan at 100%
