Help with Performance Expectations w/ 2 Card Choices (720p)
RunDougRun
162
I need help with what to expect in terms of graphics with these 2 cards......I've been limited to what I can play by my GPU and have these 2 choices available (From Friends)
My Comp:
-Amd Phenom IIx4 955 (3.2-3.6ghz Stable)
-6gb Ram
-Windows 7
-600 Watt Bronze Power Supply (Corsair Builder Series)
Card Choices:
-Gtx 750ti
or
Radeon R9 270X
I know 720p isn't as demanding (or ideal) as 1080p but its what I have for now.....
What Presets/performance can I expect on most games.....
I know I will be CPU limited on some of the newest AAA Titles.....
Thanks in advance
The R9 270X is the card you want...more powerful than the 750 Ti, and you have a PSU (albeit not the greatest) that will cater for it in terms of the required PCI-E connectors.
Yeah that's the one I was leading towards.....
On 720p what can I expect for performance.....Again, I hear 720p isn't very demanding....
I should be able to play most games on "High" or "Ultra" depending on the game?
Yeah based on those charts, 720p should be a breeze.......
What do you think the HIGHEST card my cpu can handle.....
Someone said around a gtx 960 or R9 290x
I'm no CPU expert but I suspect you would be hard pushed to max out the 270 with a Phenom II. Your best option would be to get the best stable overclock possible or upgrade to a 980 (given its the top AM3 processor) and overclock the bejeezus out of that.
with a 4ghz overclock you should just about top out at a gtx 960/ r9 380, still would bottleneck in cpu bound games though
dont even think of a 290x with your current setup
XD
With my Case (Thermaltake Chaser A31) and 6 fans and Evo Cooler, I can get 3.6-3.8 Stable......
Cant get much higher......Not sure if I have a bad motherboard or if it's just not that overclock friendly.....
So assuming I can only get 3.6-3.8ghz what would be the highest you recommend....
Honestly, the 270x would be SUCH an upgrade from my gtx 460 and seems like it would do wonders on 720p
grab a gtx 960
a 270x isnt bad either though if your budget is an issue
So a Gtx 960 would be good if my cpu is @3.6ghz....
Not too bad of a bottleneck?
