So sorry if this is the wrong thread to post this.
I have revently built my first gaming rig. Specs below.
When I first power the pc on after turning on the power at the wall the computer will shut down for about 2 seconds then start up again.
To what I can tell this only happens when switching the pc on when it has been disconnected from the power socket.
If I shut down the pc and turn back on it does not do it.
On another note when I first turn it on after connecting the power the fans at much more louder and higher speed, once it shuts down and starts up again they are quiet.
Note I have followed the process of elimination, swapped the psu for a new one and it does the same. Also tried starting with different ram.
Any help would be apprecieted.
CPU: AMD - Ryzen 7 1800X 3.6 GHz 8-Core Processor
CPU Cooler: Corsair - H100i PRO 75 CFM Liquid CPU Cooler
Motherboard: Asus - ROG STRIX X470-F Gaming ATX AM4 Motherboard
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive
Storage: Seagate - BarraCuda Pro 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI - GeForce RTX 2070 8 GB Video Card
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA G3 750 W 80+ Gold Certified Fully-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home Full 32/64-bit
Wireless Network Adapter: Asus - PCE-AC68 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter
Case Fan: Corsair - ML140 Pro 97 CFM 140mm Fan
Case Fan: Noctua - NF-F12 PWM chromax.black.swap 54.97 CFM 120mm Fan
Monitor: Dell - S2716DG 27.0" 2560x1440 144 Hz Monitor
Other: ROG Addressable LED Strip (30 cm, Aura Sync RGB, magnetisch Casemod)
Thanks
Scott
Thanks
Scott
