Help with PSU
aron_6
6
I'm looking about mining ETH or ZEC.
My specs Will be:
- intel core 2 duo E8400 @ 3GHz
- 4GB DDR3 Memory @ 1333 MHz
- Gigabyte R9 290 windforce
- Zotac R9 280x
What PSU would you recommend. PC Will be on 24/7. Will 700W or 750W be good?
I would go with a 600/650w (personally) Or even a really good 550W. Either Seasonic, or one of the Corsair RMX range. Reliability and longevity is the key here. Aim for a good make, and as high up the tier list as your budget allows.
Are you sure 650 would be enough? Every psu calculator recommends more than 700w
