Hello everyone!
My wonderful girlfriend is having some issues with her R9270X Asus Direct CUII 2GB DDR5 card. I'll attach a pic of what we see.
So the issue first came about when launching Overwatch. It would load and then almost immediately go to a white or grey screen. We would get a message (only sometimes, if it didn't freeze the PC) that the application crashed due to driver issues. Verified and updated all GPU drivers, verified BIOS is up to date, and now when we power on, the system will POST, and youll get to the screen with the blue windows logo and the loading circle, but after that goes away the screen goes dark, and starts looking for inputs from other sources and it's the end of the line. I did some basic troubleshooting and swapped my card into her PC, Overwatch loads and plays just fine. to verify it was 100% a GPU issue I also swapped her card into My PC. When its in my PC, I get a bunch of thick, red horizontal lines where the POST (ROG boot screen) screen should be, and it actually goes as far as loading into my desktop for about 10 seconds, before the screen does dark and the GPU light on my 4 stage LED POST indicator illuminates indicating a fault.
I am 99% sure she has a faulty graphics card but I am curious if anyone can elaborate on some details regarding what on the card could have failed? if its fixable maybe as money is tight and we cannot really afford a new card at this time.
I should add that if I boot the PC into safe mode, it will take me to the desktop but again you see these green/purple distortions on screen in multiple areas just like in the attached picture.
Her core specs:
M5A99FX PRO R2.0 MOBO
RADEON R9 270X GPU
AMD FX8350 CPU
Thanks for your time.
Her core specs:
RADEON R9 270X GPU
AMD FX8350 CPU
