Hello,
I am building a custom loop PC and just about to mount radiators with the case View 71.
https://images-na.ssl-images-amazon.com/images/I/51gypPGfw8L.jpg
This is the stock photo I found on google. This is pretty much where I was thinking to mount radiators onto.
But, isn't this setup bad for the airflow?
FRONT: 3 x 120mm fans pushing air in to the case but
SIDE mounted radiator pulling air out as soon as the air comes in from the front?
So here, I am not sure if I should just mount the radiator to the front side and leave the side blocked with a plate.
Any advice will be helpful.
Thanks in advance.
Cheers
Thanks in advance.
Cheers
