Help with reservoir
An AFK User
384
I'm going to buy an Enthoo Luxe. I want to use a tube reservoir but my gpu is too long to use the reservoir bracket with. My question is how would I mount my reservoir like this so it doesn't get in the way of my gpu. If someone tells me how this guy did this, I'm going to buy this res (assuming it is an EK XRES100 d5 pump combo) http://imgur.com/GDoZ6lv
If he places it there he might have trouble with tube clearance with the rear fan and would also have to drain his loop and remove the res to install or pull out an adjacent expansion card (unless he uses soft tubes). A double 5.25" bay res is still the better option.
Why would he have to drain? Placing a tube res in the position you showed would block the expansion cards, how would a bay res do that? It'd be nowhere near the expansion slots.
That's... not what I meant. I meant that literally every time he'd want to move a PCIe card he would have to drain the system and move the res. With a bay res it's just one initial drain-and-fill.
