Hello!
I'm currently installing my first PC and would very much appreciate some help with hooking up my case fans. My setup is as follows:
Cooler master h500p case
ASUS Prime z370 A motherboard
2 x 200mm cooler master RGB fans in the front, both are on a cooler master adapter that came with the case and have both a male and female RGB/LED 4 pin connector remaining.
2 x 200mm cooler master RGB fans on top, both with 4 pin female RGB/LED connector and 3pin female PWM.
1 x 140mm coolermaster RGB fan on the back, with 4 pin female RGB/LED connector and 4 pin female PWM.
FYI, they may not be called RGB/LED connectors, but you check out the adapter here.
http://www.coolermaster.com/cooling/cooling-rgb-accessories/1-to-3-rgb-splitter-cable/
Ideally, I'd like all connected to the motherboard with the ability to change the color either through the software, or possibly with the reset button.
My mother board has the following headers.
1 CPU fan header (occupied by CPU fan) with 4 pin PWM
1 CPU OPT header (unoccupied) with 4 pin PWM
2 x CHAS fan headers (both unoccupied) with 4 pin PWM
1 x AIO fan/pump header (unoccupied) with 4 pin PWM
1 x M.2 header (unoccupied) with 4 pin PWM
1 x EXT fan header (unoccupied) with 5 pin PWM header
1 x RGB header (unoccupied)
I've spoken to ASUS's customer service and they gave me a few bits of information that may help. The rep said that the RGB header was only used for LED strips. He also said that the CPU OPT, AIO and M.2 headers can be used for case fans. And he said that ideally the rear case fan should be hooked to the EXT header.
So my current plan is to adapt the rear 4 pin female PWM to a 5 pin female for the EXT slot. Hook the two top fans, using their 3 pin PWM connectors, to the CPU OPT and CHAS Fan 1 header. Then I'm left with the 2 front fans, attached to the adapter (1 female and 1 male RGB/LED connector remaining).
Questions:
1. Will RGB fans work on the listed fan headers? How will I be able to control the color? Do I need the RGB controller?
2. What type of adapter do I need for to convert the female or male RGB/LED connector to a 4 PWM female connector?
3. Is what the rep told me correct? I called during an off hour and motherboards weren't his specialty.
Thanks so much for the help! Any insight would be appreciated.
Questions:
