Help with RPC Rremote Procedure Call)!!!!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.terminalserver.misc (More info?)
I need someone to explain what it is and how to fix it!!!
| Newsgroups: microsoft.public.windowsnt.terminalserver.misc
| Subject: Help with RPC Rremote Procedure Call)!!!!
| Date: Thu, 24 Jun 2004 15:20:38 -0400
| Organization: Posted via Supernews, http://www.supernews.com
| Message-ID: <10dmaceclungge6@corp.supernews.com>
| X-Priority: 3
| X-MSMail-Priority: Normal
| X-Newsreader: Microsoft Outlook Express 6.00.2600.0000
| X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2600.0000
| X-Complaints-To: abuse@supernews.com
| Lines: 3
| Path:
cpmsftngxa10.phx.gbl!TK2MSFTNGXA01.phx.gbl!cpmsftngxa06.phx.gbl!TK2MSFTNGP08
..phx.gbl!newsfeed00.sul.t-online.de!newsfeed01.sul.t-online.de!t-online.de!f
eed.news.tiscali.de!uio.no!news.tele.dk!news.tele.dk!small.news.tele.dk!sn-x
it-02!sn-xit-01!sn-xit-06!sn-post-01!supernews.com!corp.supernews.com!not-fo
r-mail
| Xref: cpmsftngxa10.phx.gbl
microsoft.public.windowsnt.terminalserver.misc:16249
| X-Tomcat-NG: microsoft.public.windowsnt.terminalserver.misc
RPC is a powerful technique for constructing distributed, client-server
based applications. It is based on extending the notion of conventional, or
local procedure calling, so that the called procedure need not exist in the
same address space as the calling procedure. The two processes may be on
the same system, or they may be on different systems with a network
connecting them. By using RPC, programmers of distributed applications
avoid the details of the interface with the network. The transport
independence of RPC isolates the application from the physical and logical
elements of the data communications mechanism and allows the application to
use a variety of transports.
Are there particular problems you are having? Can you explain the symptoms?
Derek Wirch, MCSE+I (NT 4.0), MCP (Win2k)
Microsoft Exchange Support Engineer
Enterprise Messaging Support - Admin
Email: a-derekw@microsoft.com
Please respond in the group, so all users may benefit.
Even if you're on the right track, you'll get run over if you just sit
there.
SECURITY ANNOUNCEMENT:
Please subscribe to the FREE Microsoft® Security Notification Service on
http://register.microsoft.com/subscription/subscribeme.asp?ID=135 an e-mail
alert service geared toward IT professionals. We use this service to notify
subscribers when we release an important security bulletin or virus alert,
and also to make them aware that they might need to take action to guard
against a circulating threat. You should also bookmark Microsoft Security
Bulletin's page available at
http://www.microsoft.com/technet/treeview/?url=/technet/security/bulletin/
to view all our bulletins. To insure you are current with all security
patches visit Windows Update at http://windowsupdate.microsoft.com to
install patches. Running the SCAN program from the Windows Update site will
keep you up-to-date.
>-----Original Message-----
>| From: "Studioworkx USA" <info@studioworkx.com>
>| Newsgroups:
>| X-Priority: 3
V6.00.2600.0000
>| Lines: 3
>| Path:
>r-mail
>| X-Tomcat-NG:
it!!!
of conventional, or
processes may be on
with a network
transport
the application to
if you just sit
>there.
p?ID=135 an e-mail
action to guard
Microsoft Security
with all security
>Thanks Derek!!
I found that I had a worm in my computer that was causing
it to go haywire. It would pop up and say it was shutting
the system down, and it was an on and off situation only
happening once and awhile. Then finally it got to the
point that after startup it would go directly into
shutdown and I would have to safe start the computer and
it would operate long enough for me to finish a few
projects. Again THANK YOU!!! for your help!!
Randy.
