[SOLVED] Help with Ryzen 5950 X ASUS ROG Dark Hero Voltage, Speed and Temps
Aug 29, 2021
Hello, I recently got a 5950x build with an ASUS ROG Dark Hero motherboard. While I am in BIOS my BIOS shows that my CPU is running at 1.44v and 50c on idle.. I am not sure if this is normal. When I start windows and go into the task manager I can see that my CPU Speed is stuck at or slightly above 4.0ghz. This is with optimized defaults on the BIOS. Any help configuring the Dark Hero BIOS and the Ryzen 5950x would be much appreciated. With HWinfo I can see that my V Core voltage fluctuates between 1.3 and 1.4 on idle. My temps with HWinfo are 40c-50c on Idle and 60c - 75c during gameplay. I just want to make sure that my cpu is not doing something that it is not supposed to and is running normally
My system specs are
Ryzen 9 5950x
ASUS ROG Dark Hero Mobo
Nvidia RTX 3090
32gb of 3600 G SKILL TRIDENT Z Neo
Please let me know if there is any other info that would be helpful.
