I've got two Klipsch speakers I want to setup to be used with my computer. Problem is I'm not super savy when it comes to speakers/soundsystems so I could use some help figuring out how to go about this. I've got an old AV Receiver (from my parents) laying around which I figured I could use and possibly a giant subwoofer in the basement in storage. For sound on my PC i've got a dedicated sound card although I've barely used it so I really don't know if it's any good.
I'll post pictures of the AV Receiver and the speakers and any other information I can give that might help you guys help me. I figure I need some kind of cable that can hook into the AV receiver and the speakers via their clamp on the back. Any help would be appreciated. I can also go down and get a picture of the subwoofer if needed but it seems a little big for my room.
Here are the images:
http://imgur.com/a/Cz0Vk
EDIT:
Just thought that I would clarify what I'm trying to do. I want to connect my PC to the AV receiver to the speakers so the computer outputs sound to the speakers. Video is going directly from GPU to monitor. I know how to setup the software side, but it's the hardware side of connecting the right cables that presents a problem for me.
EDIT 2:
I should mention that I have an optical port on my soundcard, so I figure that I should use an optical cable from the AV to the soundcard? Still need to figure out how the speakers connect to the receiver. I took a picture of the back of the soundcard, might be kind of hard to see since it was under my desk.
EDIT:
EDIT 2:
