Help with system design, $2000 budget
ddaigle
41
So ... I'm looking to build a monster rig. I want raw, not overclocked power (since I do not know how to overclock properly). I've built many PC's, my problem is I don't keep up with all the components. Seems I'm only interested in such a thing when it comes time to do a new build every 2yrs-ish 😛
With that in mind, I'm looking for a definitive list of parts that will last me through the next 2-3 yrs. No need for a case, or any peripherals. Just the meat and potatoes.
The extreme is a bit ott 😛 4 way sli is a total waste, and the on board sound is worse 😀 The formula supports dual sli and has good sound 😉 plus it looks better 😀 and around $70 cheaper
Donimator is overpriced, and not worth it, Vengeance Pro is the way to go 😀 (these are my opinions btw)
Investing more in a mobo means one is looking for specific features or OC capability. This motherboard is pretty solid No1 it comes with a combo deal. No2 it is good for OC but if you wanted to go extreme you could always rather go for a more expensive one. No3 If you are highly interested in extreme mobos then it would be good to invest more. No4 it really isn't a step down since motherboards with higher prices tend to OC better that's all in simplest terms. No5 It's a awesome motherboard for the price and it fits in your budget. It also has very good sound features.
So what features will I lose exactly between the one you linked, and the Maximus VI that I had? What kind of performance loss?
The motherboard has nothing to do with performance loss upto this point of class of motherboards (don't forget this). Basically the maximus 6 has awesome OC potential over the Asrock z87 but I thought you won't be OCing at least not very much.
Any hoo have a look at the sites here are some features of the boards:
ASUS MAXIMUS 6 EXTREME MOTHERBOARD
http://www.asus.com/Motherboards/MAXIMUS_VI_EXTREME/
ASROCK Z87 EXTREME 4 MOTHERBOARD
http://www.asrock.com/mb/intel/Z87%20Extreme4/
By the way if you live near a micro centre go and pick up the i7 they have it for 60$ cheaper there.
Sadly, it looks like the deal they have on the 4770k is in store only and I dont live near one =/
its not to bad, but get vengeance PRO RAM, its better and cheaper 😀
Yea, idk how that ram slipped through on that build. I have already decided to go with the vengeance pro ram.
So that MSI mobo isn't bad? Just wondering how it compares to the maximus vi for being such a big price difference.
Well... the extreme is naturally better. That mobo has dual sli support (anymore is usually wasted) but only on 8/8. Its mildly worse in speed, and you get no oc panel. Plus its yellow (i hate yellow 😀)
Overall, its $100 less for a minor performance hit (btw, my fav mobo is the maximus vi formula, might be worth a look 😉)
Why the formula over the extreme just curious
