Help with taskkill scheduled task.
Jun 18, 2018
6
Hi,
I am trying to set up a task to occur a minute after startup to kill RGBfusion.exe I created a .bat file with the following text:
taskkill /F /IM RGBFusion.exe
taskkill /F /IM Check_Kill.exe
I have selected this .bat file in the actions section of the new task window and set it to occur a minute after start up but nothing happens.
When I try just opening the .bat file it only works if I run as admin, only then does it kill the two programs.
What I am doing wrong?
Any help or instruction on how to do this properly would be most appreciated.
Matt
