help with the ASRock B150 PRO4/D3 ATX motherboard...
VagelisZampras
11
Hey, I have some questions about the asrock b150 pro4/d3.
1.Does it support the gigabyte gtx 980 ti?
2.Would it bottleneck any parts in this build?
http://pcpartpicker.com/p/smJ6YJ
3.Also how does the i7-6700 skylake cpu on this build above perform for gaming and video editing?
Thanks in advance
PCPartPicker part list: http://pcpartpicker.com/p/vvyjt6
Price breakdown by merchant: http://pcpartpicker.com/p/vvyjt6/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($329.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.88 @ OutletPC)
Motherboard: Gigabyte GA-H170M-D3H Micro ATX LGA1151 Motherboard ($89.99 @ SuperBiiz)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2400 Memory ($66.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive ($63.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Amazon)
Total: $685.72
Generated by PCPartPicker 2016-02-07 13:40 EST-0500
spend a little more for the newer ddr4 mb and ddr4 ram the faster the ram the better it is for rendering. the power supply you picked out was not a good unit to use in a gaming pc. for the gpu hold off till april as the newer pascal gpu are dropping then. the 980ti or newer will fit any mb and will work fine. just make sure the case is not too small or has bad airflow. look for newer gaming cases with the open top grills to let heat out.
VagelisZampras
11
yeah good solution but about the ram, the one you suggest is much more expensive where I live. Also I will consider about the gpu, and check out the new pascal gpu. Thanks for the motherboard suggestion :D
Latest posts
