Help!!!! With these work together?????
Mitchell7643
51
i want to install a SAPPHIRE Radeon HD 6450 1GB 64-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card into my brother's PC.
His motherboard is an MSI P965 NEO
Will these work together?
It should work just fine. The motherboard's PCI Express version is 1.1 and is compatible with the PCI-E 2.1 graphics card. The card should draw all the power it needs directly from the PCI-E slot. Even a low-powered power supply should be able to supply the max 75 watts the PCI-E slot provides.
-Wolf sends
-Wolf sends
