Help with tower build
KielG413
My first post was in social networking somehow, but I think it belongs in here.
I'm looking for a basic desktop to stream with. Doesn't need anything fancy, I have a very old pc that isn't powerful enough and the laptop I'm using doesn't have a good enough amount of RAM or a decent cpu.
I'm looking for the most basic options with no extras, just enough raw power and processing speed to stream with the newer streaming software. My budget is very low and I am not looking to spend more than $500 to 600$ Even less if its an option
I plan on using the desktop to only stream.Nothing else.
Thanks to all of you who have the time to help.
Pre built towers are acceptable as well.
Basic Intel build with good performance.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($175.88 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($61.98 @ Newegg)
Memory: Crucial Ballistix Tactical Tracer 8GB (2 x 4GB) DDR3-1600 Memory ($48.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($60.00 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked ACX Video Card ($112.99 @ Best Buy)
Case: Cougar Spike MicroATX Mini Tower Case ($32.99 @ SuperBiiz)
Power Supply: Antec Green 450W 80+ Bronze Certified ATX Power Supply ($39.99 @ Directron)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.45 @ OutletPC)
Total: $596.16
Generated by PCPartPicker 2015-10-04 20:25 EDT-0400
Is the SSD needed? I don't use dual storage and SSDs for me haven't loaded much faster to be noticeable and I work with graphics development. Even on my ps4 a SSD isn't worth it. it loads like 7 seconds faster (the menus only)
No, the SSD is not needed. If a regular drive works for you that's fine. Instead, you could upgrade the CPU to a Xeon 1231 v3 which would give you the benefits of hyperthreading that an i7 has or increase the ram to 16GB or upgrade the graphics to GTX 960 or pocket the savings.
