[SOLVED] Help with undervolting Rx570
Robbom
70
Recently attempted to undervolt an rx570 in a system as its temperatures were a little on the high side. Started by lowering the state 7 core voltage by around 30mV each time and then ran heaven benchmark to see the results with adrenaline metrics overlay running to show statistics. The confusing thing was at as low as 1075mV (Default is 1150) I was still getting higher wattage used by the GPU (around 115 W as opposed to around 100-105 at default, power limit set the same for both). While the default kept the core clock constant the undervolt actually caused it to throttle down slightly, before heat even became an issue. Am I just missunderstanding this process? Advice would be really appreciated, cheers
As an FYI, here's some points along the curve that I've generally found stable for most cards.
1000MHz = 890mV
1100MHz = 910mV
1200MHz = 940mV (this 940mV is typically an inflection point on the curve, it gets steeper above this value. Notice that values below this are ~25mV/100MHz and values above are 100mV/100MHz)
1300MHz = 1030mV
1400MHz = 1150mV
If the stock frequency was 1244MHz, it would seem to me that auto voltage would probably feed around 1075mV (even though it may have been higher when you unlocked it in the WattMan window). In that case, the GPU may have been getting ~1075mV on Auto voltage anyway. Did you see 1150mV in GPUz for a significant period of time (or was it just a brief spike)?
My personal MSI Gaming X RX480...
There's two ways of undervolting.
  1. Full manual like the guy in your video is doing. This shouldn't affect even 1% lows. In fact it should improve them initially because you're achieving a more stable clock speed because you're not constantly bumping against the power limit ceiling.
  2. Leaving everything on auto and sliding a "voltage offset" slider. That's going to reduce your clock speed because the GPU is still riding along the "stock" frequency/ voltage curve.
Reactions: Robbom
1000MHz = 890mV
1100MHz = 910mV
1300MHz = 1030mV
1400MHz = 1150mV
My personal MSI Gaming X RX480 8GB supplies ~1075-1125mV @ 1305MHz when left on Auto voltage.
For some reasons, I managed to get stable 1455mhz @ 1140mV on my powercolor rx 570 lmao, but i rarely use that preset since it got hot real quick, even tho i managed to stay under 80c
