Hello fellow system builders.
Wow its been awhile since I have bought anything new for my computer but I am looking to upgrade. Since I have been out of the loop for quite some time I need some advice. I don't have too much money to spend, so I am debating on if I should upgrade my GPU or just build a whole new system. I want to get a GTX 560 but I am not sure if I will be bottle necking with my current setup. If that is the case and I need to build anew, what are my best options for a budget of $1k. Here is my current setup:
Mobo: EVGA LGA 775 NVIDIA nForce 750i SLI FTW ATX Intel Motherboard
CPU: Intel Core 2 Quad Q8200 2.33GHz LGA 775 95W Quad-Core Processor
GPU: EVGA Geforce GTX 260
Memory: CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM 1066 Dual Channel Kit
PSU: CORSAIR HX Series CMPSU-620HX 620W ATX12V v2.2 and EPS12V 2.91
OS: Microsoft Windows XP Professional With SP2B 1 Pack - OEM
LCD: ASUS VW224U Black 22" 2ms(GTG) Widescreen LCD Monitor (resolution 1680X1050)
I usually go Intel but willing to check out AMD if the performance is good vs price. I also was wondering if SSD cards will increase game performance or just load times and are they worth the money. Any help would be greatly appreciated.
Thanks,
Anthony
Thanks,
Anthony
