Help with video card 750Ti
david_705
open
Hello everyone hope someone can help me. I installed an IDE hdd to my PC I was gonna put it as a secondary hdd ,the primary is a SATA . After installing it and powered it back on , the screen came up with white stripes unable to see clearly.I uninstalled the IDE hdd and just left the SATA drive ,however the screen keeps​ coming back up with stripes. The PC has a a video card Nvidea 750Ti that was working greatly prior to connecting the secondary ide hdd. I already reseated the video card and reset the BIOS batt but the white stripes persists and made sure everything was plugged in correctly. I also disabled the Video card and used the onboard video VGA and the video works fine, I updated the drivers for the video card but when I boot using the video card the screen is covered with frozen white stripes.
When I first put the Ide hdd and booted , it seemed to have corrupted windows on my SATA drive, I fixed that by restoring windows but now I am left with a video problem.
The PC doesn't seem to be reconizing the video card , as when I use GeForce experience to update I get error "unable to locate hardware" at times it does, but wont let me update . In device manager shows Nvidea hardware but with the orange exclamation.
Now I am wondering if I damage my video card?
device manager says : Device PCI\VEN_10DE&DEV_1380&SUBSYS_362D1458&REV_A2\4&d7fef2c&0&0010 requires further installation.
Specs of pc:
Mobo: Gygabite GA-78LMT-usb3
Graphic card: Geforve Nvidea 750Ti
Power supply : Pixxo JaquarPW 600w
Ok so i just noticed that windows is still updating, since it got restored currently 45% do you think it could be because is still updating ,is not recognizing the GPU?
just did a clean installation of the driver for the gpu prior to noticing that windows was still updating ,same outcome.
If you have graphics or driver issues, one of the most common fixes is a clean uninstall and removal of your graphics drivers.
To uninstall your drivers, first download and run Display Driver Uninstaller, and follow it's recommendations of booting into safe mode and ect.
(This is a direct download link so you don't grab the wrong version)
http://www.guru3d.com/files-get/display-driver-uninstaller-download,20.html
You'll download a compressed file called "[Guru3D.com]-DDU.zip"
Right click and choose extract.
Go into the folder and run the DDU v##.##.exe
This will extract more files to this folder.
Run Display Driver Uninstaller.exe
Choose Yes when it asks you to boot into SafeMode.
After you've rebooted into safe mode.
When DDU comes up, if it hasn't selected your GPU manufacturer (Nvidia/AMD/Intel) then choose it from the drop down list
Press the Clean and Restart option
If a window comes up asking to disable the Windows automatic installation of display drivers click yes.
After (or before removing the old drivers, just put the new ones on the desktop or somewhere handy) rebooting back into Windows, manually download the latest drivers from Nvidia or AMD, don't use auto detect, choose you GPU model and OS from the drop down lists.
Nvidia: http://www.nvidia.com/Download/index.aspx?lang=en-us
AMD: http://support.amd.com/en-us/download
Intel: http://www.intel.com/content/www/us/en/support/detect.html
Ok so i tried it but it didnt help, do you think it has to do with the fact that windows is not updating? stuck at 45%
