Odd you should provide a link to a video to tell us what GPU it is - - why not just tell us what it is?
Anyway, yes the Sapphire R7 260x will fit on that motherboard - - PCI Express x16 slot. The motherboard has one of those.
Just make sure your existing PSU has sufficient wattage to drive it. It needs to be at least 500w and a good quality brand.
The PSU must also have at least one 6-pin PCI Express power connector cable coming from it to plug in to the Sapphire card.
