Help - XP and ZoneAlarm
Brian
1,371
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I'm seting up my first XP machine. I have 2 users, me as
administrator and my wife as a basic user. Every time my wife logs
off and I log on Zone Alarm crashes and has to be rebooted, but it
diesn't happen when I log off and my wife then logs on. I've tried
searching for advice with no luck, can anyone help please?
Brian
Have you asked Zone Alarm?
Mary Sauer MSFT MVP
http://office.microsoft.com/
http://msauer.mvps.org/
news://msnews.microsoft.com
"Brian" <briansngfbox@btopenworld.com> wrote in message
news:epgjh152cmt7qgvm0hligeg68unaa3sft4@4ax.com...
> Brian
On Sat, 3 Sep 2005 15:02:52 -0400, "Mary Sauer"
Yes in parallel with this post, no reply yet
Brian
use the msconfig to disable the zone alarm. to be sure that it is zone
alarm.
I had same problem... i installed another anti-virus.. AVG .. its
problem free mate.. and it works fine.
Brian, I had the exact same problem when switching between two accounts
(when switching from account 1 to 2, all was OK, but when switching from 2
to 1, ZA died).
I'm using the latest build of the Suite. I completely uninstalled and
reinstalled and that fixed it for me. Here's how I did it. Note that you'll
lose all of your configuration settings so if you need to write down your
firewall entries, etc. do it now.
1. Set ZA so that it does not startup with the OS (Overview | Preferences)
2. Reboot
3. Uninstall ZA from Add/Remove Programs
4. Delete the directory "Internet Logs" (C:\WINDOWS\Internet Logs)
5. Reinstall
Brian
>to 1, ZA died).
>2. Reboot
>5. Reinstall
>Brian
Thanks Rick. I found a work around after my OP. Unchecking load at
start up and starting ZA\manually - by whoever loged on first -
stopped the problem. I'd also reinstalled once, but without removing
the log.
Brian
Brian
i would yus zone alarm.
> Brian
