help
G
Guest
Guest
i forgot my xp set up password. can anyone tell me what can i do, please.
thanks
I think there's a utility out there called NTFS Pro and you would boot up with that on a floppy and would have to delete the SAM file on your harddrive.
If that doesn't work, you'd need to find some 3rd party utility to help ya out, sorry =\. Gotta write em down if thier not burned in your head!
<font color=red>:</font color=red> <font color=white>:</font color=white> <font color=blue>:</font color=blue>
<A HREF="http://www.iopus.com/password_recovery.htm" target="_new">iOpus Password Recovery XP</A>
<A HREF="http://www.lostpassword.com/windows-xp-2000-nt.htm" target="_new">Windows XP/2000/NT Key</A>
These are typical examples of password recovery software that are functional with WinXP.
Your other option is to reinstall the operating system. Afterwards, you should make a <A HREF="http://www.techtv.com/callforhelp/answerstips/story/0,24330,3356093,00.html" target="_new">password recovery disk</A>.
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new"><font color=green>Toejam31's Tantalizing Tantric Toy</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
____________________________________________________________
<font color=purple>"Procrastination on your part does not constitute an emergency on my part."</font color=purple>
