Question help
Jul 8, 2019
4
Ever since I got my new computer I've been having trouble with my WIFI connection. It is very slow and is telling me I'm only at one bar meanwhile my family members are all at full bars. I asked my friends if they know what the problem is but they have no clue, so I came here.
Important information:
I have Verizon FiOS
The router is only one floor below my PC (Not that far according to my friends)
My PC is a pre-built HP Pavilion Gaming Desktop 790-0020
My monitor is an ASUS MG248QR Gaming Monitor
I don't know if any of this information helps and I'll try and get all the details you ask for I just don't know what to put.
Ralston18
Does not take much to interfere with a wireless signal and those bars are not all that reliable per se.
What wireless network adapter are you using: built-in, PCIe, USB? Make and model?
Are you sure that only one network adapter (wired or wireless) is enabled on your new computer? One or the other - not both.
Who has full admin rights to your home router? The router's logs (if available and enabled) may provide some clue.
And, also with respect to the router, you need to work with the router's admin to ensure that your network adapter is properly configured for wireless connectivity to the router.
On your new PC - are you able to run and post the results of "ipconfig /all" via the command prompt?
Jul 8, 2019
4
I'm pretty sure my wireless network adapter is built-in. I don't know what make and model it is and I don't know where to check.
Only have one network adapter is enabled.
Everyone in my house has full admin rights to my router, because it's wireless. I don't know where to check the router's logs.
I don't know what that means. (Sorry)
Yes, here they are:
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-BT9VG7H
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : fios-router.home
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 10-E7-C6-10-AB-0D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : fios-router.home
Description . . . . . . . . . . . : Realtek RTL8821CE 802.11ac PCIe Adapter
Physical Address. . . . . . . . . : FC-01-7C-20-CD-C1
Link-local IPv6 Address . . . . . : fe80::193c:553:ebc5:e8a2%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.194(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, July 8, 2019 4:22:11 PM
Lease Expires . . . . . . . . . . : Wednesday, July 10, 2019 5:27:58 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 83624316
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-6E-D4-71-10-E7-C6-10-AB-0D
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
fios-router.home
Ethernet adapter Hamachi:
Description . . . . . . . . . . . : LogMeIn Hamachi Virtual Ethernet Adapter
Physical Address. . . . . . . . . : 7A-79-19-09-4C-2D
IPv6 Address. . . . . . . . . . . : 2620:9b::1909:4c2d(Preferred)
Link-local IPv6 Address . . . . . : fe80::591e:5b67:92cb:38ae%22(Preferred)
IPv4 Address. . . . . . . . . . . : 25.9.76.45(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Obtained. . . . . . . . . . : Monday, July 8, 2019 4:21:58 PM
Lease Expires . . . . . . . . . . : Tuesday, July 7, 2020 4:21:58 PM
Default Gateway . . . . . . . . . : 2620:9b::1900:1
25.0.0.1
DHCP Server . . . . . . . . . . . : 25.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 805458162
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3
Physical Address. . . . . . . . . : FE-01-7C-20-CD-C1
Wireless LAN adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : AnchorFree TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-0F-17-65-B1
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : FC-01-7C-20-CD-C2
DHCP Enabled. . . . . . . . . . . : No
What u just provided have minimum impact on my views, I work with real numbers. Numbers say the truth.
So SLOW doesn't tell me anything, run a speedtest and post result.
Everybody has a cellphone right, so too, run a speedtest on your phone at the same location where the PC is. Compare results with above. Ideally run these test when nobody is at home or they all asleep.
Verizon FIOS, again doesn't tell me anything, What is the speed of the Internet service purchased?
Is there an antenna on the back of the PC? be sure is screwed on snug.
Jul 8, 2019
4
My router has 2 networks, one is called FiOS-VL604, and the other one is called FiOS-VL604-5G. My dad said that the FiOS-VL604 had a weaker connection but had more range, meanwhile the FiOs-VL604-5G had a stronger connection but is only used for downstairs. I don't know if any of that info helps but I put it there anyways.
I also don't know what a speedtest is so I searched it up on Google and it gave me this:
7.62
Mbps download
18.0
Mbps upload
Latency: 6 ms
Server: New York, NY
Your Internet speed is typical
Your Internet connection should be able to handle streaming an HD video. If multiple devices are streaming video at the same time, you may run into some slowdowns.
The FiOS-VL604 is 400 Mbps and the other one is 900 Mbps (I think)
Also, I don't have an antenna behind my PC. Am I supposed to have one?
