Question Help!!!
COLGeek
Cybernaut
If highly accurate color is a showstopper for you, you should consider workstation (professional) GPUs and 10-bit displays.
The info for both previously mentioned displays seems "mixed". Either would meet the needs for all but the most demanding of users.
What applications/uses are you trying to optimize through your selection? What are the specs for the system that will be connected to this display?
Feb 9, 2020
9
intel core i7 6800k
asus x99 deluxe 2
rog strix 1070ti
main specs are these
