I have a Z490 tomahawk, I9-10900K, 32gb ballistix system and I keep getting BSODS, freezes and crashes randomly... I'm unsure if it's caused by temps or the fact that for CPU power i only have the 8pin not the 8+4 due to my PSU only being a CX550
rx 560, currently saving for an 80+ gold 750 (went from an i5-2400 so a big jump haha)using a GPU ?
i would step up to a decent 750w/850w to start anyway !!
https://www.userbenchmark.com/UserRun/62501583to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
update the BIOS of the motherboard to the latest version using m-flash within BIOS
View: https://www.youtube.com/watch?v=LRyFMf0D9Lc
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
How to perform a clean boot in Windows - Microsoft Support
Describes how to use the clean boot process to troubleshoot a problem in Windows 8.1, Windows 8, Windows 7, or Windows Vista.support.microsoft.com
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
run the RAM @2133MHz to check if it happens then too
check the hard drive for errors with its manufacturer´s tool
modern AIO's are fine i personally use arctic freezer ii ive got the 360 and 420mm but a 280mm should be perfect for the 10900k..https://www.userbenchmark.com/UserRun/62501583
BIOS was already updated few days ago
windows integrity tool passed
checking memory on memtest as of posting will update once complete
Edit: failed at Round 5-6% of pass 1 with 514 errors, I'm gonna let it keep running for now
2nd edit: froze a 0:45:03, status failed, errors 514 pass of 19% test 37% test#6
3rd edit: passed after a few bios changes and a swap around of ram sticks, although i am still worried about temps.. is an AIO worth the risk of leaks?
