Helps with chose the right VGA-Card and PSU with Q6600 CPU!!
olivertrinh
Commendable
Jun 20, 2016
12
What PSU should i get with my ddr2 low-ends:
-E6750( upgrade to Q6600 soon)
-4GB RAM(upgrade to 6GB or 8GB with the Q6600)
-GT610 (this is trash for 50$, so i'm going to upgrade to a GT730-OC,GT740-OC,GT-750TI, depends on the bottle-neck on the Q6600)
-1TB Blue HDD
-1 Asus Blue-ray
No water-cooling or big-thermal, just Basic stock CPU fan and 1 fan each on the back,front, side (cheap office case)
i'm just a poor guy with a dream of playing MotoGP-14 and some racing game in very-low setting with at least 60fps. I just need a playable, not a very good one.
Please help me pick the right card and the right PSU without OC, thanks for and comments and sorry for any grammar mistake, i'm Asian.
really appreciate for the fast reply and the info you provide, i'll look for it, and also, it's there any need for the cooling to change? because i'll use all of them in Stock, non-OC.
Thank you very much.
so the hyper cpu thermal with giant block will works? i'll try to find 1 for cheap price. Thanks friend.
because i have a LGA775 at home right now, i just dont wanna spent into main, maybe i'll upgrade it later after 1yr. Maybe G3258 or i34160
wow, i'm so curious, how can you know so much :)
