H hamid esnn Reputable Jul 24, 2015 5 0 4,510 Jul 24, 2015 #1 Hi, I have an HP laptop,i replace battery and now when i use on battery my laptop shotdown immediatly after cooling fan turn on, what going on?
Solution B B boosted1g Jul 24, 2015 You don't need to repeat your exact post, also the Title area is for a short description, that is why it got cut off. Did you buy an OEM battery (meaning it has the HP logo on the battery), or did you buy a knock-off "replacement" battery?
B boosted1g Titan Jun 12, 2013 14,846 8 74,965 Jul 24, 2015 Solution #2 You don't need to repeat your exact post, also the Title area is for a short description, that is why it got cut off. Did you buy an OEM battery (meaning it has the HP logo on the battery), or did you buy a knock-off "replacement" battery? Upvote 0 Downvote Solution
H hamid esnn Reputable Jul 24, 2015 5 0 4,510 Aug 1, 2015 #3 boosted1g : You don't need to repeat your exact post, also the Title area is for a short description, that is why it got cut off. Did you buy an OEM battery (meaning it has the HP logo on the battery), or did you buy a knock-off "replacement" battery? Upvote 0 Downvote
H hamid esnn Reputable Jul 24, 2015 5 0 4,510 Aug 1, 2015 #4 Hi,THX for ur information... I buy an OEM battery from bestbuy on Us... Upvote 0 Downvote
B boosted1g Titan Jun 12, 2013 14,846 8 74,965 Aug 2, 2015 #5 Just because you bought it from best buy does,not,mean it is one. Does the battery have an HP logo on it? Upvote 0 Downvote
H hamid esnn Reputable Jul 24, 2015 5 0 4,510 Sep 26, 2015 #6 boosted1g : Just because you bought it from best buy does,not,mean it is one. Does the battery have an HP logo on it? Upvote 0 Downvote
