Hi Everyone,
my budget for the new computer is something between 5000-5500.
Gaming computer.
My friend built this one for me:
CM8064601464506 - Intel
i5-4670K Quad core CPU - LGA1150 - 3.4 GHz - 6MB cache - 22nm - 84W TDP - Integrated HD Graphics 4600 at 1200Mhz - Works with Z87,H87,B85 Chipsets only - Haswell Series - Tray
CM8064601464506
GA-Z87P-D3 - Gigabyte
Socket LGA1150 CPU (Haswell, Broadwell) support - Intel Z87 chipset - Dual channel DDR3 up to 1600 MHz memory - Integrated Graphics HDMI video output - 2 PCI Express x16 slots - 4 PCI slots - 8-channel audio - Gigabit LAN - 6 SATA3 6Gb/s - Up to 6 USB3.0 - ATX
GA-Z87P-D3
F3-12800CL9D-8GBXL - G-Skill
8GB (2x4GB Kit) DDR3-1600MHz, PC3-12800, CL-9-9-9-24, Ripjaws-X series
F3-12800CL9D-8GBXL
GTX760-DC2OC-2GD5 - ASUS
Geforce GTX760 GPU - 2GB GDDR5 256 bit memory - PCI-Express 3.0 interface - 2-Slot DirectCU II cooler - Dual DVI, DisplayPort, HDMI video outputs - GPU/Memory clock 1072/6008 MHz
GTX760-DC2OC-2GD5
CT120M500SSD1 - Crucial
120GB M500 Series - SATA3 6Gbps 2.5 inch Internal SSD - 500 MBps Read / 130 MBps Write
CT120M500SSD1
ST1000DM003 - Seagate
1TB - 3.5 inch - SATA3 6Gb/s - 7200rpm - 64MB Cache - Barracuda 7200.14 series - (ST1000DM001)
ST1000DM003
Three-Hundred - Antec
Three Hundred Case - No Power Supply included - External 3 x 5.25 bays - Internal 6 x 3.5 bays - 1 rear 120 x 25 mm TriCool Fan with 3-speed switch control - 1 top special 140 x 25 mm TriCool Fan with 3-speed switch control - 2 front (optional) 120 mm fans to cool the hard drives - 1 side (Optional) 120 x 25 mm Fan to cool graphic cards - Washable air filters - Top mounted USB and Audio ports - Dimensions 45.8 (H) x 46.5 (D) x 20.5 cm (W) - ATX
Three-Hundred
VP-650P - Antec
VP-650P - 650W - ATX12V v2.3 compliant - 120mm silent fan - 8pin cpu connector - 6pin PCIe connector
VP-650P
RR-H101-22FK-RU - Coolermaster
Hyper 101
How it looks?
more offers will be welcome.
Thank you very much
Gaming computer.
CM8064601464506
GA-Z87P-D3
F3-12800CL9D-8GBXL
GTX760-DC2OC-2GD5
CT120M500SSD1
ST1000DM003
Three-Hundred
VP-650P - Antec
VP-650P
Hyper 101
How it looks?
Thank you very much
