Hi peeps I need help with a bit of Software
Kirk Martin
6
I have this great little spyware software remover, however I deleted it by accident and cannot remember where to get it.
It was more like a portable app. Had a rectangle box which had 3 options. Scan, delete and uninstall. I pressed uninstall and it removed the software completely.
So anyway this software was great, for quick spyware removals, you would hit delete it would do a quick scan and remove the spyware very quickly...
If you know the link to this wonderful bit of software, could you post it here as I really did like using it!!!
Thanks again.
