J jamesbobbibby Reputable Feb 6, 2015 20 0 4,510 Mar 4, 2015 #1 I dont know what size fan would fit in my case where the big holes are. i have the picture right here with a ruler.
Solution USAFRet Mar 4, 2015 http://www.thermaltake.com/products-model_Specification.aspx?id=C_00001772 Cooling System Front (Intake) : 120 x 120 x 25 mm (optional) Rear (Exhaust) : 120 x 120 x 25 mm Blue LED fan, 1000rpm, 16dBA Top (Exhaust) : 120 x 120 x 25 mm (optional) Bottom (Intake) : 120 x 120 x 25 mm (optional) So...a 120mm fan.
USAFRet Titan Moderator Mar 16, 2013 179,719 22,217 184,590 Mar 4, 2015 #2 Since your ruler is not aligned with the relevant holes, it is hard to tell. What case is it? Upvote 0 Downvote
J jamesbobbibby Reputable Feb 6, 2015 20 0 4,510 Mar 4, 2015 #3 THERMAL TAKE COMMANDER MS-I RED/BLACK. I want red/black fans, cheapest ones on pcpartpicker, canada. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,719 22,217 184,590 Mar 4, 2015 Solution #4 http://www.thermaltake.com/products-model_Specification.aspx?id=C_00001772 Cooling System Front (Intake) : 120 x 120 x 25 mm (optional) Rear (Exhaust) : 120 x 120 x 25 mm Blue LED fan, 1000rpm, 16dBA Top (Exhaust) : 120 x 120 x 25 mm (optional) Bottom (Intake) : 120 x 120 x 25 mm (optional) So...a 120mm fan. Upvote 0 Downvote Solution
