Hi guys, I am experiencing in game stutter during all games on my new build. Have done some testing and discovered the following (all software, os, bios and drivers are updated. Using monitoring tools memtest86 (4 passes no errors), prime95, cpu-z, realtemp, msi afterburner, furmark, LatencyMon). The i7 4790k is set to stock clock of 4ghz and the ram is set to xmp profile of 1866mhz.....
FURMARK @ 2560x1440 (2x MSAA)
note: It was mostly butter smooth with the odd micro stutter for a minute or so during the ten min test.
FPS: 39 (min 31, max 41)
GPU1: 69 c (min 47 c - max 70 c)
core: 1379 MHz / 70 c / 99%
mem: 3505 MHz / 10%
GPU Power: 74.8% TDP,fan: 51%
CoreTemp standalone BEFORE using Prime95
frequency 4400.00 MHz
processor #0
Core #0 = 24 c (Min 22 max 56) load 0%
Core #1 = 22 c (Min 19 max 59) load 0%
Core #2 = 20 c (Min 19 max 57) load 0%
Core #3 = 25 c (Min 23 max 54) load 0%
CoreTemp with Prime95
processor #0
power: 170 watts
Core #0 = 95 c (min 22 max 98) load 100%
Core #1 = 99 c (min 19 max 100) load 100%
Core #2 = 98 c (min 19 max 100) load 100%
Core #3 = 90 c (min 23 max 96) load 100%
The GPU temp from the test seems ok? They also seem ok when monitoring via msi afterburner. However, the CPU result with prime95 and coretemp seem really high? Could this be the cause of the problem? What are the possible solutions? Do I need to reapply thermal paste between the cpu and h100i cooler? Also when using RealTemp under no load the thermal status for the cores reads: LOG LOG LOG OK
however when running alongside prime95 it would often read: LOG HOT HOT OK.
Many thanks in advance for the replies.
system:
i7 4790k
16gb 1866mhz cas 9 ram
120gb samsung evo 850 ssd
seagate 2tb 7200rpm hdd
msi gaming 5 z97 mobo
gigabyte gtx 980 g1 gaming windforce edition
corsair h100i
evga g2 750w psu
corsair k70 rgb keyboard
corsair h2100 headphones
trust gxt 152
asus rog swift pg278q
mem: 3505 MHz / 10%
processor #0
processor #0
power: 170 watts
system:
i7 4790k
corsair h100i
evga g2 750w psu
trust gxt 152
