Question High Idle Temps (Need Help)
Aug 11, 2022
19
Recently my PC's temps have been spiking up again with idle temps at 77C, even tho coolant is around 33C.
Cpu is 7 5800x
Aio H100i Platinum SE
Thermal paste is MX 4
and the case is 465x icue with 5 fans in total including radiator ones
The thermal paste is brand new and applied it 2 days ago. I made sure the aio is tightened up but still very high idle temps.
I tried everything and im at a roadblock. Any suggestions?
Perfect, it seems your problem was fixed. Now I'm off to make a complaint at razer for their synapse messing up AIO pumps and preventing them from running full power. (this is a joke, i'm too lazy to open a ticket with razer support)
I'm glad your problem is no more.
Takoss123 i will never forget you thank you for the help man!
Phaaze88 aswell!
Synapse... if it wasn't needed for Razer hardware I would advise against it.
Razer in same place Logitech used to be, people buy their hardware regardless of software being bad. If/when someone over takes them, then they might fix Synapse.
I haven't moved my pc in um... 2 years so I don't have the air problem. Have to think about that when I do move it next.
