Question High pitched noise from PC after installing AIO ?
May 9, 2021
Hi, I recently installed an AIO on my custom built pc. A high pitched noise occurs when my motherboard power light turns on before the bios. The high pitched whining is louder after I close down an intensive game. Any ideas on a fix?
My specs are:
CPU: AMD ryzen 7 2700x
GPU: EVGA rtx 2080ti black
RAM: corsair vengance 2x8 (2 sticks)
MOBO: MSI b450 carbon ac pro wifi
CPU AIO: msi core liquid 240r AIO
POWER SUPPLY: EVGA SuperNOVA 850 G+
Try to determine the source of the high-pitched noise.
Open the case prior to boot up and listen while booting and then while closing down an intensive game.
You can use a cardboard tube or rolled up sheet of paper to focus your hearing as you carefully listen about your system to locate the source of the noise.
