Hi, I have a Cooler Master 140xl AIO CPU cooler and this is the 3rd CPU cooler I have received due to the first two having worse problems, (fans weren't working with each other, constant high pitch sound and they basically weren't cooling the CPU down properly.)
So, this problem I have had with all of them is the High Pitched sound coming from the pump. I have no clue what is doing it. I've unplugged the pump from the mobo a couple of times to know IT'S the pump.
I do believe it has nothing to do with power because I unplugged my Crossfire setup. (hogs of power) I've even moved the ram sticks to different channels, changed cases and changed PSU's.
Also, in between moving cases, I removed the thermal paste on my CPU so, it's not a damaged CPU.
It's not coil whine, more like a hard drive doing it's thing.
I've replaced the O.G Fans with Corsair 140sp fans. Fan noise is horrendous.
Here's my build:
i5 4690
Asrock H97 Fatality
G Skills Sniper 2x4gb
R9 280x Sapphire
R9 280x XFX
Inwin 800w Gold+ PSU
Samsung Evo 840 120gb
Seagate Barracuda 1TB
Asus Optical Drive.
3rd Cooler, First world problem.
Here's my build:
i5 4690
Asrock H97 Fatality
R9 280x Sapphire
R9 280x XFX
Asus Optical Drive.
