"High Power" model HLP-800BE-F14S power supply
dforrest
99
I have a "High Power" model HLP-800BE-F14S power supply which is in a system I have purchased. Can anyone give me any information on the reliability of this? It is marked "80 Plus Bronze Certified".
D
Manufacturer marketing materials aren't really helpful. 3rd party reviews are the only reliable way to see if a unit is good quality or not. It meets 80 Plus Bronze certification and is listed here because of that:
https://plugloadsolutions.com/psu_reports/HIGH%20POWER%20ELECTRONIC%20CO.,%20LTD._HPL-800BR-F14S%20(C)_800W_ECOS%203989_Report.pdf
Edit: Link doesn't work. This will. https://tinyurl.com/ybhgje46
That's also meaningless as 80 Plus is only a measure of efficiency and not quality.
All that anyone will be able to give you is a guess but as I said above my best guess is that's is a midrange unit. Not dangerous to use but not meant for higher end systems or overclocking.
I emailed High Power asking for details when I could not find that model listed and they replied "HPL-800BR-F14S is only available in select channels, and therefore doesn’t list on High Power’s website". They sent me a spec sheet which I can send to you if you are interested.
