High Power PSU Brand
johnlewis804
73
Hello
I just brought a new pc and it has a psu brand called High Power. Its a 600 watt power supply 80 plus psu. Has anybody herd of this company? Are they good? Should i replace it asap?
(PSU Model: High Power HPG-600ST-F12S)
Thanks
The 600w is enough for you system. On good spec on almost all of their psu is they will putout 90% + of the rated power from just the 12 rail or rails. I would stick with it for now.
here are my system specs its not really a power heavy build
8GB DDR3 1600 MHZ MEMORY
1TB SATA III 3.5" HARD DRIVE
GTX 680
WINDOWS 8.1 64-BIT
asrock z97 anniversary
INTEL i7-4790K 4.0 Ghz
